*beamsectionupdateshellpartname
Renames a HyperBeam shell section part.
*beamsectionupdateshellpartname beam_sect_id part_index new_name
HyperMesh Tcl Modify Command
beam_sect_id
The ID of the shell beam section to update.
part_index
The index of the part to rename for that shell section, starting from 0.
new_name
The new name of the part.
Examples
To rename the part with index 3 for shell beamsection ID 100 to "edge4":
*beamsectionupdateshellpartname 100 3 edge4
   # Handle error
Version History
10-SA1-130
