*hwct_deleterepsfromlibrary
Deletes representations from a connected library.
*hwct_deleterepsfromlibrary entity_type mark_id params
HyperMesh Tcl Modify Command
entity_type
The type of connected library. Currently only supported for subsystems.
mark_id
The ID of the mark of entities. Valid values are 1 and 2.
params
A quoted, comma separated string, containing additional optional name=value parameters. Valid parameters are:
comment=<value>
The comment to add for the action.
Examples
Delete crash representation for subsystem 2 from the library:
*createmark subsystems 1 2
*hwct_deleterepsfromlibrary subsystems 1 crash "removedcrash"
   # Handle error
Version History
2020
