*CE_FE_CreateDCC
Creates all connector control default entities.
*CE_FE_CreateDCC reserved
HyperMesh Tcl Modify Command
reserved
Reserved for future use, must be set to 0.
Examples
To create all connector control default entities:
*CE_FE_CreateDCC 0
   # Handle error
Version History
2021
