*spatialrenumbering
Renumbers nodes and elements based on spatial locations.
*spatialrenumbering entity_type <option1>=<value1> <option2>=<value2> ... <optionN.=<valueN>
HyperMesh Tcl Modify Command
entity_type
The type of entity to renumber. Valid values are nodes and elements.
type=<type>
The type of renumbering, axis or adjacent.
Adjacent only works with quad4 or quad8 elements and associated nodes.
startid=<startid>
The ID to be assigned to the first entity. The value must be an unsigned integer. This option also works with parameters of integer type.
primaryidincrement=<primaryidincrement>
The ID increment in the primary direction. The value must be an unsigned integer. This option also works with parameters of integer type.
secondaryidincrement=<secondaryidincrement>
The ID increment in the secondary direction. The value must be an unsigned integer. This option also works with parameters of integer type.
The following options apply to type=axis only:
systemid =<systemid>
The ID of system. For global system, a value of 0 must be used. The system should be either Cartesian or cylindrical.
primaryaxis=<primaryaxis>
The primary axis of the system. x=1, y=2 and z=3 for Cartesian systems. r=1, θ=2 and z=3 for cylindrical systems.
primarytolerance=<primarytolerance>
The allowed tolerance between entities in the primary direction. The value must be a double. This option also works with parameters of double type.
secondaryaxis=<secondaryaxis>
The secondary axis of the system. x=1, y=2 and z=3 for Cartesian systems. r=1, θ=2 and z=3 for cylindrical systems. This must not be equal to primaryaxis.
secondarytolerance=<secondarytolerance>
The allowed tolerance between entities in the secondary direction. The value must be a double. This option also works with parameters of double type.
The following options apply to type=adjacent only:
startentityid=<startentityid>
The ID of the start entity. This entity must be same as entity_type.
primaryentityid=<primaryentityid>
The ID of the primary entity. This entity must be same as entity_type and must be adjacent to the start entity.
secondaryentityid=<secondaryentityid>
The ID of the secondary entity. This entity must be same as entity_type and must be adjacent to the start entity.
A few notes about type=adjacent:
  • If the entity type for all three options is nodes, all three entities must belong to a common element apart from being adjacent to each other.
  • For quad8 elements, only provide ids of corner nodes of a common element as start, primary and secondary entity ID. Mid nodes as prime inputs are not supported.
  • The IDs of non-selected entities will be renumbered if any conflict arises during renumbering.
  • A single entity cannot be renumbered using this method.
  • If a secondary entity is not specified, or set as 0, the row/column containing the start and primary entities will be renumbered.
Examples
Renumber nodes using axis type and local system 1 with primary axis 1 and secondary axis 2:
*createmark nodes 1 all
*spatialrenumbering nodes mark=1 type=axis systemid=1 startid=100 primaryaxis=1 primarytolerance=0.2 primaryidincrement=1000 secondaryaxis=2 secondarytolerance=0.2 secondaryidincrement=1
Renumber elements using adjacent type and integer parameter named priInc (parameter value 100) used as primary ID increment by name:
*createmark elems 1 all
*spatialrenumbering elems mark=1 type=adjacent startentityid=555 startid=1 primaryentityid=557 primaryidincrement={parameter name=priInc} secondaryentityid=556 secondaryidincrement=1
Renumber a single column/row of nodes using adjacent type. Only a single column/row of entities will be renumbered:
*spatialrenumbering elems mark=1 type=adjacent startentityid=41 startid=1 primaryentityid=40 primaryidincrement={parameter id=5} secondaryentityid=0 secondaryidincrement=1
   # Handle error
Version History
14.0.120
