*CE_FE_SetSpecificDetailById
Changes a single FE detail for a connector specified by ID.
*CE_FE_SetSpecificDetailById ce_id detail_type int_val dbl_val
HyperMesh Tcl Modify Command
ce_id
The desired connector’s ID.
detail_type
The number of a detail:
Detail: # Range: Meaning:
config 1 >0 FE configuration type of the realized connector
    2 plot
    3 weld
    5 rigid
    2
1
spring
5
5
rigidlink
    6
0
bar2
    6
1
rod
7
0
gap
    1
0
4
quads
    1
0
0
1
custom
tolerance 2 >=0.0 Tolerance value for FE realization.
property_ID 3 >0 FE property ID
systems 4 0,1 Build system flag:
0=do not build systems
1=build systems
snap_to_node 5 0,1 FE snap to node flag
0= do not snap to node
1= snap to node
remesh 6 0,1 FE remesh flag
force_collinear 7 0,1 FE force collinear flag:
0 = non-collinear
1 = collinear
fe_type 8 >0 FE type value defined in the feconfig.cfg file
non_normal 9 0,1 Nonnormal projection:
0 = normal
1 = nonnormal
allow_adjacent 1
0
0,1 Allow adjacent projection:
0= don’t allow
1= allow
solver 1
1
>=0 Solver type for FE realization
fevector_reverse 1
5
0,1 Vector reverse flag for seam connector
trim_surf_each_side 1
6
0,1 Flag to trim surf at each side for area connectors
connectivity 1
7
0,1,2 Connectivity type:
0 = independent
1 = dependent
2 = use shell node
area_thick 3
1
0,1,2,3 Area connector thickness type:
0 = (T1+T2)/2
1 = shell gap
2 = mid thickness
3 = const thickness
area_const_thick 3
2
>0.0 Constant thickness for area connectors.
area_stack_size 3
3
>=0 Density for area connectors.
bolt_min_dia 4
1
>=0.0 Minimum diameter for bolt hole.
bolt_max_dia 4
2
>=0.0 Maximum bolt hole diameter.
app_mass_mass 5
1
>=0.0 Mass for applied masses.
app_mass_dis 5
2
0,1,2,3 Applied mass distribution type:
0= all nodes
1= divide by nodes
2= divide by area
3= unit area
int_val
The value for integer details.
dbl_val
The value for details with decimals.
Examples
To set tolerance to 10.0 for connector 3:
*CE_FE_SetSpecificDetailById(3, 2, 0, 10.0)
Details with decimals in the listed "range" use the dbl_val while details without them use the int_val.
This command is outdated. The following commands are recommended for the purpose of setting details for connectors:
