*midmesh_inspect_delete_sets
Deletes sets created in the midmesh inspect module.
*midmesh_inspect_delete_sets mode
HyperMesh Tcl Modify Command
Deletes sets created in the midmesh inspect module. This must be preceded by a call to *midmesh_inspect_init.
mode
1 - Delete all midmesh inspect sets
2 - Delete empty midmesh inspect sets
Examples
To detect and correct nodes off mid, delete empty sets, and shut down the inspect module:
*createmark components 1 "shell"
*createmark components 2 "MidmeshEdges" "Mid"
*midmesh_inspect_init SourceEntityType=components SourceMark=1 TargetEntityType=components TargetMark=2 MinNodeOffMidDeviation=0.2
*midmesh_inspect_fix_problems nodes 2 ProblemType=NodeOffMid SmoothClusters=1 SmoothMethod=Auto
*midmesh_inspect_delete_sets 2
*midmesh_inspect_end
   # Handle error
Version History
2021
