*hf_RejectDragDeleteHandle
Rejects the edit binder drag operation.
*hf_RejectDragDeleteHandle int_flag
HyperMesh Tcl Modify Command
This command rejects the edit binder drag operation.
int_flag
0 - Reject the drag or delete handle.
1 - Reject the binder update after drag handle.
Examples
To reject the drag or delete handle:
*hf_RejectDragDeleteHandle 0
To reject the update binder after drag:
*hf_RejectDragDeleteHandle 1
   # Handle error
Version History
11.0.101
