*createstringarray
Creates an array of strings for use in a subsequent command.
*createstringarray size strings
HyperMesh Tcl Modify Command
size
The size of the array.
strings
The strings to put in the array.
Examples
To create a string array with the strings "abc" and "def":
*createstringarray 2 "abc" "def"
