*markersupdate
Updates multiple MBD markers.
*markersupdate mark_id node_id syst_id sys_flag color update_node update_syst update_color
HyperMesh Tcl Modify Command
This command updates MBD analysis markers.
mark_id
The ID of the mark containing the markers to be updated. Valid values are 1 and 2.
node_id
The ID of the node that defines the location of the markers.
syst_id
The ID of the orientation coordinate system.
syst_flag
A flag for the coordinate system. A value of 0 indicates that the coordinate system will be blank.
color
The color of the markers.
update_node
A flag indicating if the node will be updated.
0 - do not update the node
1 - update the node
update_syst
A flag indicating if the system will be updated.
0 - do not update the system
1 - update the system
update_color
A flag indicating if the color will be updated.
0 - do not update the color
1 - update the color
To update markers m1 and m2 to both use orientation system ID 25:
*createmark sensors 1 "m1" "m2"
*markersupdate 1 0 25 1 0 0 1 0
   # Handle error
Version History
10.0
