*hwct_synclibrary
Synchronizes library information from a connected library.
*hwct_synclibrary entity_type mark_id params
HyperMesh Tcl Modify Command
Synchronizes library information from a connected library. This includes information such as Major Revision, Study Revision and Library Revision.
entity_type
The type of connected library. Currently only supported for subsystems.
mark_id
The ID of the mark of entities. Valid values are 1 and 2.
params
A quoted, comma separated string, containing additional optional name=value parameters. Currently not supported.
Examples
Synchronize library related information for subsystem 2:
*createmark subsystems 1 2
*hwct_synclibrary subsystems 1
   # Handle error
Version History
2020
