*ME_ModulePosition
Positions a module using its hierarchical transformation matrices.
*ME_ModulePosition id position reserved
HyperMesh Tcl Modify Command
id
The ID of the module to position.
position
0 - Transform to the normal position. This is the position the module will arrive to after applying all necessary hierarchical relative matrices.
1 - Transform to the original position. This is the neutral position the module might be saved in the original representation file as. It is the original position before hierarchical relative matrices are applied.
reserved
Reserved for future use. Must be set to 0.
Transform module part 168 back to its original representation file position:
*ME_ModulePosition 168 1 0
   # Handle error
Version History
14.0
