*createentity
Create a new entity with specified data.
*createentity entity_type ?modelname=<name_of_model>? ?name1=value1? ?name2=value2? ... ?name3=valueN?
HyperMesh Tcl Modify Command
Create a new entity with specified data. Data names only are allowed to be set.
There are also a few limitations to this command:
  • Attributes are not supported.
  • STATUS is not supported.
entity_type
Entity type to create.
<name>=<value>
The name=value data name and/or attribute pairs that define the relevant data for the entity. For attributes, this can be either the attribute name or ID.
For entity attributes, both the entity type and the entity IDs must be provided. For example:
*setvalue elements id=7 3222={elems 3}
This is the optional model name to update when there are multiple models in the database. If not specified, the current model is used.
Examples
Create a set with a default set type and name.
*createentity sets
Create a set of type nodes and node IDs 1-4:
*createentity sets type=nodes ids={1 2 3 4}
Create a set with name set1, cardimage GRNOD:
*createentity sets name=set1 cardimage=GRNOD
   # Handle error
Version History
13.0
2020.1 - Added new option modelname.
