*surfacemarkclipwithline
Splits a group of surfaces with a line by projecting that line perpendicularly onto the surfaces.
*surfacemarkclipwithline mark line tolerance
HyperMesh Tcl Modify Command
mark
The mark ID containing the surfaces.
line
The ID of the line used to split the surfaces.
tolerance
The maximum distance the line may deviate from the surfaces and still be projected.
To split two surfaces using line number 26 and a projection tolerance of 0.1:
*createmark(surfaces,1)171 172
*surfacemarkclipwithline(1,26,0.1)
