hm_getlinepointsatdistance
For a given line, test point, and distance, this command finds all of the line points that are at the specified distance from the test point.
hm_getlinepointsatdistance lineID dist x y z
HyperMesh Tcl Query Command
lineID
ID of the line.
dist
Distance from the test point.
x, y, z
Coordinates of the test point.
The result is returned as a list of values: { x1 y1 z1 x2 y2 z2 … }where "xn" "yn" "zn" are coordinates of points on the line that are at distance "dist" from the test point defined by "x", "y", "z".
   # Handle error
