hm_getprojceid
Returns the ID of the connector from the FE weld data array for a given index.
hm_getprojceid index
HyperMesh Tcl Query Command
Returns the ID of the connector from the FE weld data array for a given index. This command should only be used from within a connector-registered property script (which is executed during connector FE realization). The projection data this function relies upon is removed immediately after connector FE realization.
index
The index of the weld in the FE weld data array.
To get the connector ID for the 10th index in the weld data array:
set ce_id [hm_getprojceid 10];
   # Handle error
