hm_attributeidfromname
Returns an attribute ID from the attribute name for the current template.
hm_attributeidfromname attribute_name
HyperMesh Tcl Query Command
Returns an attribute ID from the attribute name for the current template. If the attribute does not exist in the current template, an error is returned.
attribute_name
The name of the attribute to query.
To get the attribute ID of the OptiStruct PSHELL_T attribute:
hm_attributeidfromname PSHELL_T
   # Handle error
Version History
10-SA1-110
