hm_getelementsqualityinfo
Computes quality parameters for the specified selection of elements.
hm_getelementsqualityinfo elementmask criteria_use_mode failed_mask ?panel_sensitive?
HyperMesh Tcl Query Command
elementmask
The markmask of the input element (1 or 2).
criteria_use_mode
1 The quality criteria must be explicitly set beforehand. If the parameter is not given, 1 is used as the default value.
0 The default quality criteria adjusted to the selected averaged element size are automatically created if the criteria do not exist.
failed_mask
The markmask of the failed element (0, 1, or 2). If not specified, 0 is used. Must be different from elementmask.
panel_sensitive
Can be used when multiple panel levels have been pushed, either using the shortcut function keys, or the hm_pushpanel command. This option determines whether to use the current panel or the previous panel for the operation. This option is relevant only when the mark has been created from a panel entity selector under the above conditions. Valid options are:
0 - Use the previous panel.
1 - Use the current panel (default).
Output values are organized in the following list:
total number of elements on the markmask
number of failed elements
quality index
% of failed elements
% of trias
None.
