hm_getlinetype
Returns the line type.
hm_getlinetype line_id
HyperMesh Tcl Query Command
Returns the line type. Return values are:
  • 0 - Free line
  • 1 - Free surface edge
  • 2 - Shared surface edge
  • 3 - Non-manifold surface edge
  • 4 - Suppressed surface edge
line_id
The ID of the line.
To get the type of the line with ID 341:
hm_getlinetype 341
   # Handle error
