hm_entitymaxsolverid
Returns the maximum solver ID in use for an entity type.
hm_entitymaxsolverid entity_type ?id_pool_name?
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
id_pool_name
An optional argument, indicating whether the maximum internal ID should be considered over all ID pools or a specific ID pool only.
To get the maximum solver ID for properties:
hm_entitymaxsolverid props
To get the maximum solver ID for properties in the two_idpool property ID pool:
hm_entitymaxsolverid props two_idpool
   # Handle error
