hm_comparegetcomparea
Returns the comparison area of a specific component.
hm_comparegetcomparea match_type match_location ?component_id? ?transformation_index?
HyperMesh Tcl Query Command
Calculates the area values for a specific component. This must be preceded by a call to a relevant hm_compareentities* command. hm_comparesetflags should also be set to 1.
match_type
The type of match to query for the area. Valid values are:
0 - Unmatched
1 - Topological
2 - Intersected
3 - Overlapped
4 - Matched
match_location
The location of the entities to query for the area. Valid values are:
1 - Source entities
2 - Target entities
component_id
The ID of the component to query. If not specified, or given as 0, then the area for the entire source or target is calculated (same behavior as hm_comparegetarea). Ensure that the specified ID matches with the requested match_location.
The index of the transformation to query, starting with 0. The number of transformations can be found using hm_comparegettransformationcount.
Examples
Compare assembly 1 to assembly 2 and query the area of component 10:
*createmark elems 1 "by assems" 1
*createmark elems 2 "by assems" 2
hm_compareinit
hm_comparesetflags 1
hm_compareentitiessameside elems 1 elems 2 1.0 2 0
hm_comparegetcomparea 4 1 10
hm_compareend
   # Handle error
Version History
2020
