hm_getmodelcheckdisplaynames
Returns check display names.
hm_getmodelcheckdisplaynames ?check_type? ?entity_type?
HyperMesh Tcl Query Command
check_type
The type of check, ERROR, WARNING, INFO or ALL. If blank then all checks of all types are returned.
entity_type
The type of entity. If ALL, then checks for all entity types in the profile are returned.
Examples
To get the check names for all check and entity types:
or
hm_getmodelcheckdisplaynames ALL
To get the check names for ERROR for mats:
hm_getmodelcheckdisplaynames ERROR mats
   # Handle error
Version History
2019
