hm_fe_getdiameter
Returns the diameter value set for weld or property creation.
hm_fe_getdiameter
HyperMesh Tcl Query Command
Returns the diameter value set for weld or property creation. The value of the diameter is the global value set internally from the panel or through the commands.
To get the diameter value:
set diameter [ hm_fe_getdiameter ];
None.
