hm_cardimageassignedtoentity
Indicates if a card can be assigned to the entities on the mark for the current template.
hm_cardimageassignedtoentity entity_type mark_id
HyperMesh Tcl Query Command
Returns 1 if a card can be assigned to the entities on the mark for the current template, 0 otherwise.
entity_type
The type of entity to query.
mark_id
The ID of the mark of entities to query. Valid values are 1 and 2.
Examples
To query components 100 and 101:
*createmark comps 1 100 101
hm_getimageassignedtoentity comps 1
   # Handle error
Version History
2019
