hm_getwhollycontainedcollectormark
Returns the collectors that wholly contain the input entities.
hm_getwhollycontainedcollectormark entity_type entity_mark_id collector_mark_id reverse
HyperMesh Tcl Query Command
This command returns the collectors that wholly contain the input entities.
entity_type
  • The type of entity to query. Valid values are:
  • elems (output is components)
  • loads (output is load collectors)
  • curves (output is plots)
  • systs (output is system collectors)
  • vectors (output is vector collectors)
entity_mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
collector_mark_id
The ID of the mark containing the collectors that wholly contain the input entities. The collector type is dependent on the specified entity_type. Valid values are 1 and 2.
reverse
  • 0 - Find only wholly contained collectors.
  • 1 - Find not-wholly contained collectors.
Examples
To find the components that wholly contain elements 1-100:
*createmark elems 1 1-100
hm_getwhollycontainedcollectormark elems 1 1 0
To find the components that simply contain elements 1-100:
hm_getwhollycontainedcollectormark elems 1 1 1
   # Handle error
Version History
11.0.101
