hm_getadvancedselectiontypes
Returns a list of valid advanced selection strings for the specified entity type and mode.
hm_getadvancedselectiontypes entity_type ?mode?
HyperMesh Tcl Query Command
entity_type
The entity type to query.
mode
Specifies whether to return only the advanced options exposed in the GUI (0, default), or all options including those currently only exposed via Tcl (1).
Examples
To get the list of all advanced selection strings valid for comps:
hm_getadvancedselectiontypes comps 1
   # Handle error
Version History
2019
