hm_findclosestpointonline
For a given point on a line, returns the closest other point on that same line.
hm_findclosestpointonline x y z line_id ?return_type?
HyperMesh Tcl Query Command
For a given point on a line, returns the closest other point on that same line:
xc yc zc dist
where xc, yc and zc are the coordinates of the point on the line closest to input point, and dist is the distance between the original and projected points.
x y z
The coordinates of the known point.
line_id
ID of the line.
return_type
0 - Returns xc, yc, xc and dist as described above. This is the default if not specified.
1 - Returns xc, yc, xc and arclen, where arclen is the arc length parameter, normalized between 0 and 1, that indicates the position of the found point along the length of the line.
To find the point closest to a point with coordinates (2676, -737, 605) and located on line 7:
hm_findclosestpointonline 2676 -737 605 7
2.6777E+003 -7.3989E+002 6.0481E+002 3.3889E+000
   # Handle error
