hm_attributelistall
Returns a list of all attribute IDs, names, types or type names for the current template.
hm_attributelistall value
HyperMesh Tcl Query Command
value
The type of list to return. Valid values are:
id - the attribute ID
name - the attribute name
type - the attribute type number
typename - the attribute type string
Examples
To list the IDs of all the attributes in the current template:
hm_attributelistall id
To list the names of all the attributes in the current template:
hm_attributelistall name
To list the type number of all the attributes in the current template:
hm_attributelistall type
To list the type name of all the attributes in the current template:
hm_attributelistall typename
   # Handle error
Version History
10-SA1-110
