hm_getmeshedgeparams
Returns all of the relevant automesh settings applied to that surface edge.
hm_getmeshedgeparams edge_id
HyperMesh Tcl Query Command
This command returns all of the relevant automesh settings applied to a surface edge by *set_meshedgeparams. If no automesh settings are applied, no values are returned. The returned values are (in order):
  • elem_density
  • alg_type
  • bias_style
  • bias
  • min_size
  • max_size
  • chordal_dev
  • max_angle
edge_id
The global edge ID of the surface edge to query.
To get the automesh parameters assigned to edge with ID 15:
hm_getmeshedgeparams 15
   # Handle error
Version History
10.0
