hm_proximitymarksourceproximityelements
Marks all the source elements within proximity to the given mark.
hm_proximitymarksourceproximityelements mark_id
HyperMesh Tcl Query Command
This must be preceded by a call to hm_proximityinit and followed by a call to hm_proximityend.
mark_id
The ID of the mark to which the elements will be placed. Valid values are 1 and 2.
Examples
To output the source proximity elements to mark 1 and highlight them:
*createmark comps 1 all
hm_proximityinit comps 1 2.5
hm_proximitymarksourceproximityelements 1
hm_highlightmark elems 1 h
hm_proximityend
   # Handle error
Version History
2019
