hm_bag_getentitytypes
Returns the types of entities inside a bag.
hm_bag_getentitytypes name_or_id ?search_type?
HyperMesh Tcl Query Command
This command returns the types of entities in a bag.
- name_or_id
- The name or ID of the queried bag entity.
- ?search_type?
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. The two options are:
If a bag ossetup1 consists of optimization responses and desvarlinks, then the following command will return "desvarlinks optiresponses":
hm_bag_getentitytypes ossetup1 -byname
# Handle error
}Version History
10.0
