hm_getsolverfileprofilename
Returns the profile name for an FE input file.
hm_getsolverfileprofilename filename
HyperMesh Tcl Query Command
Returns the profile name for an FE input file. This is based on the file extension. If the file extension is ambiguous, then it identifies the profile name based on the file extension and the solver format. If the file extension is missing, then it identifies the profile name based only on the solver format.
filename
The full path and filename of the FE solver file, enclosed in quotes.
Examples
To get the solver profile name for C:/temp/test.dat:
hm_getsolverfileprofilename "C:/temp/test.dat"
   # Handle error
Version History
2020.1
