hm_ce_read_mcf
Begins the process of reading a master connector file.
hm_ce_read_mcf mcf_file
HyperMesh Tcl Query Command
Begins the process of reading a master connector file. Must be followed by a call to hm_ce_close_mcf.
mcf_name
The full file path and name of the .mcf file, enclosed in quotes.
Open test.mcf to read all the data and close the file when finished:
hm_ce_read_mcf "C:/doc/test.mcf"
set get_all_data [hm_ce_mcf_getalldata]
hm_ce_close_mcf
   # Handle error
