hm_compareend
Clear memory and end the comparison module.
hm_compareend
HyperMesh Tcl Query Command
Clears memory and comparison graphics, and ends the comparison module. This must be preceded by any calls to hm_compareinit and other hm_compare* APIs.
"Major" database changes made while inside of the compare module will invalidate and delete any comparison results.
To write the detailed comparison results file to C:/temp/my_compare.txt for the same side comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0
hm_comparewriteresults C:/temp/my_compare.txt
hm_compareend
None.
Version History
12.0
