hm_morph_getmvoledgenodes
Returns the IDs of the nodes along a specified morph volume edge.
hm_morph_getmvoledgenodes edge_id
HyperMesh Tcl Query Command
edge_id
The ID of the morph volume edge.
To find the node IDs for morph volume edge 5:
hm_morph_getmvoledgenodes 5
   # Handle error
Version History
13.0.110
