hm_getunusedoremptyentities
Returns empty or unused entities.
hm_getunusedoremptyentities mode=<mode> outputmark=<mark_id> <select_type>=<selection> ?type=<entity_type>?
HyperMesh Tcl Query Command
Returns empty or unused entities, and places them on a mark. The return value is a list of lists. Each sub-list contains the empty or unused entity type as its first value, and the found entity IDs as the remainder of the sub-list. For example:
{sets 1 2} {comps 3} {mats 3 4}
mode=<mode>
The query mode. Valid values are empty and unused.
The ID of the mark to use for the output entities.
The entity or entities that are to be queried. There are several ways to provide the entities to be queried. Only one option can be used at a time:
id=<id>
The ID of the single entity to query.
name=<name>
The name of the single entity to query.
mark=<mark_id>
The ID of the mark containing the entities to query. If specified, this must be different from outputmark.
type=<entity_type>
The type of entity to query. If not specified, all entities in the database are queried.
Examples
To get the empty sets out of sets ids 1 2 3:
*createmark sets 1 1 2 3
hm_getunusedoremptyentities mode=empty type=sets inputmark=1 outputmark=2
To query all unused entities in database:
hm_getunusedoremptyentities mode=unused outputmark=2
   # Handle error
Version History
14.0
