hm_ce_getprojectiondata
Returns newly created component projection information for a given set of connectors, points, or nodes.
hm_ce_getprojectiondata entType1 mark1 entType2 mark2 numprojs tolerance order output projFlag1 projFlag2
HyperMesh Tcl Query Command
The returned data is organized into a single master list. Each element of this master list is a sublist that contains the requested connector ID, point ID, or node ID, and a list of the successfully created projections (the proj_list) for the given ID. The format of a single sublist is given as follows:
{ {connector/point/node_id}  $proj_list }
Where proj_list for 2 projections = {{comp1_id}{elem1_id}{x1 y1 z1}{u1 v1}} {{comp_2_id}{elem2_id}{x2 y2 z2}{u2 v2}}
The potentially large list this function may return, may not be the best-suited data format for most processing cases. Therefore, it is highly recommended that you use the ::CE::GetProjectionData Tclwrapper function instead. This function accepts the same set of parameters that the hm_ce_getprojectiondata function requires, but instead of returning a single large master list, it returns a randomly accessible array. The array is accessible through its use of the connector/point/node ID as the index, and at this index is the $proj_list.
entType1
Entity type on mark 1 for which projection is sought.
mark1
Mark of connectors/points/nodes that define the locations of interest.
entType2
Entity type on mark 2 to which the connectors/points/nodes are to be projected (comps only).
mark2
Mark of components to be projected onto.
numproj
Number of projections requested at the specified points (>0).
tolerance
Tolerance value for filtering projections (will be used with "numprojs").
order
0 = ordered by closest
1 = ordered through a line
output
Parameter to obtain desired output (specific projection data).
projFlag
Parameter used for projecting to COMPS (current value is zero).
projFlag2
Parameter used for non-normal projections (normal = 0, non-normal = 1).
*createmark points 1 "displayed";
*createmark components 1 "displayed";
set num_projs 2;
To get the projection data for displayed points on displayed components as a list of list:
set  proj_data_list [ hm_ce_getprojectiondata points 1 comps 1 $num_projs 0.0 0 0 0 0];
This function is optimized for the case where the projection data is required for a number of different connectors, points, or nodes, and the components that they need to be projected onto are unknown. It is especially useful for close quarter welding scenarios.
A proj_list consists of 0 or more projections in a list, with each projection having some or all of the following information:
{ {comp_id} {elem_id} {x y z} {u v} }
Note  The "output" option determines what is returned for a given projection:
  • 0 = ALL (data shown above)
  • 1 = comp_id and elem_id
  • 2 = comp_id, elem_id, and x y z
  • 3 = comp_id, elem_id, face and x y z
  • 4 = comp_id, elem_id, face, x y z and u v
The "face" value will be a non-negative number when valid external face for solid element is found during projection. If a valid face cannot be determined or if projection finds a shell element then the "face" value will be -1.
  • The number of projections can be found from using "llength" on the proj_list (which is especially easy to do when the ::CE::GetProjectionData function is used).
  • The "order" parameter returns the projection data in the requested ordering based on the closest distance to the projected connector/point/node (0) or ordered as a line (1).
  • The "projFlag2" parameter (value of 1) is used for obtaining non-normal projections useful for MIG-Welds. By default, it has a value of 0, which will return normal projections.
None.
