hm_entitymaxid
Returns the maximum internal ID in use for an entity type.
hm_entitymaxid entity_type ?recalculate?
HyperWorks Tcl Query Command
entity_type
The type of entity to query.
recalculate
An optional argument, indicating whether the maximum internal ID should be recalculated due to deleted entities. Valid values are:
0 - Do not recalculate.
1 - Recalculate (default).
To get the maximum internal ID for properties:
hm_entitymaxid props
   # Handle error
