hm_modelchecksavetoxml
Saves the config data to an XML file.
hm_modelchecksavetoxml filename
HyperMesh Tcl Query Command
Saves the config data (checks and corrections) for the current profile to an XML file.
filename
The full name and path of the XML file to save.
Examples
To save the current profile checks and corrections to C:\temp\my_config.xml:
hm_modelchecksavetoxml C:/temp/my_config.xml
   # Handle error
Version History
2019
