hm_ce_checklinkentities
Returns the names or IDs of entities added to the connector that currently do not exist in the database.
hm_ce_checklinkentities id entity_type return_type
HyperMesh Tcl Query Command
If any entities of a certain type are not present in the database, those are not returned. If all entities of a certain type are not present, an empty list is returned.
id
The ID of the connector to query.
entity_type
The type of entity to check. Valid values are assems, comps, elems, nodes, surfs and tags.
return_type
0 - Return the entity IDs
1 - Return the entity names (supported only for assems, comps and tags)
To check if components added to connector ID 1 exist:
hm_ce_checklinkentities 1 comps 0
   # Handle error
