hm_ce_setfeorientaxis
Set the axis aligned with the welds for the coordinates systems created during realization process.
hm_ce_setfeorientaxis axis
HyperMesh Tcl Query Command
axis
The axis that needs to be oriented along the weld:
0 x axis
1 y axis
2 z axis
To set y axis aligned with the welds:
hm_ce_setfeorientaxis 1
None.
