hm_encodeshape
Generate an encoded string representing the shape of a geometry.
hm_encodeshape entity_type mark_id ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Query Command
longDescription
entity_type
The type of entity to generate the encoding for. Valid values are surfs and elems.
mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
encoding_algorithm
The optional encoding algorithm to use. Valid values are:
0 - Spherical harmonics (default)
sphhar_bandwidth
Optional, valid for encoding_algorithm 0, default 16.
sphhar_fallof
Optional, valid for encoding_algorithm 0, default 2.828427.
sphhar_radii
Optional, valid for encoding_algorithm 0, default 32.
sphhar_resolution
Optional, valid for encoding_algorithm 0, default 64.
Examples
To calculate and diff the encodings from all surfaces against all elements:
*createmark surfs 1 all
set x [hm_encodeshape surfs 1]
*createmark elems 1 all
set y [hm_encodeshape elems 1]
hm_diffencodings $x $y
   # Handle error
Version History
2020.1
