hm_ce_getvalidabsolutepath
Returns a valid absolute path from a relative path.
hm_ce_getvalidabsolutepath relative_path
HyperMesh Tcl Query Command
Returns a valid absolute path from a relative path. Returns an empty string if the relative path could not be converted into a valid absolute path.
relative_path
The relative path of the file/folder. Supported relative path tags:
[ALTAIR_HOME] - Current installation base directory.
[CURRENTWORKINGDIR] - Current working directory.
[EXECUTABLEDIR] - Full directory path of the application’s executable.
[hm_scripts_dir] - HM scripts directory.
[HW_CONFIG_PATH] - Paths in HW_CONFIG_PATH environment variable.
[USER_HOME] - User home directory.
To get the absolute path for the user home relative path:
hm_ce_getvalidabsolutepath {[USER_HOME]/Some_Folder/Some_File.txt}
Returns: {C:/Users/username/Some_Folder/Some_File.txt}
   # Handle error
Version History
14.0.110
