hm_flangedetectionfindflanges
Executes the flange detection tools.
hm_flangedetectionfindflanges find
HyperMesh Tcl Query Command
Runs the flange detection functions for finding flanges based on input entities and parameters. This must be preceded by calls to hm_flangedetectioninit, and hm_flangedetectionsetparams.
find
Bit value defining the types of flanges to find (Bit0 + 2*Bit1):
Bit0
0 - Do not find 2D flanges
1 - Find 2D flanges
Bit1
0 - Do not find 3D flanges
1 - Find 3D flanges
Examples
To find 2D flanges from elements in all components, using a min width of 2, a max width of 20 and a feature angle of 20, and write out all flange details to a file named C:/temp/flanges.txt:
set flangesfile [open "C:/temp/flanges.txt" "w"]
*createmark comps 1 all
hm_flangedetectioninit comps 1
hm_flangedetectionsetparams min_width=2.0 max_width=20 feature_angle=20
hm_flangedetectionfindflanges 1
set n [hm_flangedetectiongetnumberofflanges]
if { $n > 0 } {
    puts $flangesfile "Number of flanges = $n"
    puts $flangesfile "Flanges details"
    for {set i 0} {$i < $n} {incr i} {
        puts $flangesfile "$i details = [hm_flangedetectiongetflangedetails $i]"
        puts $flangesfile "$i midline = [hm_flangedetectiongetflangemidline $i offset_dist=0]"
    hm_flangedetectionfindmates min_search_dist=0 max_search_dist=10
    set m [hm_flangedetectiongetnumberofmatinggroups]
    if { $m > 0 } {
        for {set i 0} {$i < $m} {incr i} {
            puts $flangesfile "$i = [hm_flangedetectiongetmatinggroupdetails $i]"
    } else {
        puts $flangesfile "Flange mates not detected."
} else {
    puts $flangesfile "Flanges not detected."
hm_flangedetectionend
close $flangesfile
   # Handle error
Version History
2019
