hm_writemeshcontroltemplate
Writes out the Mesh Control template file.
hm_writemeshcontroltemplate filename
HyperMesh Tcl Query Command
Writes out the Mesh Controls template file. This is an XML formatted file. This contains all of the mesh control information, except for the entity selection.
filename
The full name and path of the file to write.
To write out the file to C:/temp/meshcontrol.xml:
hm_writemeshcontroltemplate C:/temp/meshcontrol.xml
   # Handle error
Version History
14.0
