hm_getvolumeofsolid
Finds the volume of a solid entity specified by the solid entity’s ID.
hm_getvolumeofsolid solids solidID
HyperMesh Tcl Query Command
This command finds the volume of the solid solid_id. The solid argument is actually the entity type, but because this command is specifically for solid volumes, "solids" is the only valid entity type.
To find the volume of solid 3:
hm_getvolumeofsolid solids 3
Incorrect usage of hm_getvolumeofsolid results in a Tcl error. The function returns an error if the current model does not contain a solid with the given solid_id.
If { [ catch {hm_getvolumeofsolid solids $solid_id } ] } {
# Handle error here - $solid_id is not a valid solid ID.
