hm_getmodelchkvaluelevellimitcriteriaattribute
Returns model check values for level, limit, criteria and attributes.
hm_getmodelchkvaluelevellimitcriteriaattribute display_name
HyperMesh Tcl Query Command
This command returns model check values for level, limit, criteria and attributes for the specified check display name.
display_name
The display name of the check to query.
To get the attribute values for check "Material E is not defined":
hm_getmodelchkvaluelevellimitcriteriaattribute "Material E is not
          defined"
   # Handle error
Version History
12.0
