hm_proximitygetelementdistance
Returns the proximity distance for a given element.
hm_proximitygetelementdistance element_id
HyperMesh Tcl Query Command
This must be preceded by a call to hm_proximityinit and followed by a call to hm_proximityend.
element_id
The ID of the element to query.
Examples
Output the proximity distance at each input element:
*createmark comps 1 all
hm_proximityinit comps 1 2.5
hm_proximitymarksourceproximityelements 1
set elems [hm_getmark elems 1]
foreach elem $elems {
   puts "Distance for element $elem is [hm_proximitygetelementdistance $elem]"
hm_proximityend
   # Handle error
Version History
2019
