hm_morph_getnodehandle
Returns the handle ID for the specified node if a handle exists at that node.
hm_morph_getnodehandle node_id
HyperMesh Tcl Query Command
node_id
The ID of the node to query.
To get the handle ID for a node with ID 2:
hm_morph_getnodehandle 2
   # Handle error
