hm_morph_gethandlenode
Returns the node ID for the specified handle.
hm_morph_gethandlenode handle_id
HyperMesh Tcl Query Command
handle_id
The ID of the handle to query.
To get the node ID for a handle with ID 2:
hm_morph_gethandlenode 2
   # Handle error
