hm_getinputoffsetid
Returns the current import offset ID value for the specified entity type.
hm_getinputoffsetid entity_type
HyperMesh Tcl Query Command
Returns the current value of the import offset specified with *feinputoffsetid.
entity_type
The type of entity to query.
To get the offset value for elements:
hm_getinputoffsetid elems
   # Handle error
Version History
10.0
